It is currently Thu Aug 21, 2025 5:27 pm
PostPosted: Thu Nov 21, 2013 4:30 am
First name: David
Country: UK
Hi all,
I've got a comfy mexican strat 21 fret neck which I'm thinking about extending to 22 frets.
Would this be possible ? if so what would be the best way to do this, given that I have only standard diy tools.
Thanks for any tips / advice.
PostPosted: Thu Nov 21, 2013 5:28 am
Pretty easy for rosewood boards. Pull a fret (19th, 20th - whatever), cut through the fingerboard, and glue on your extension. Refret where the cut was made, level the frets, touch up the finish. Play. Make sure you measure a lot, and do your math beforehand. Done it a couple times for clients. No sweat.
PostPosted: Fri Nov 22, 2013 4:37 am
First name: David
Country: UK
hi Chris, thanks for the reply.
So this would be to cut the fingerboard, move the small piece toward the bridge, then glue in the extension fingerboard piece into the missing space and refret etc?
PostPosted: Fri Nov 22, 2013 6:10 am
I suppose you could, but I always glued on a new piece of wood.
PostPosted: Fri Nov 22, 2013 12:52 pm
First name: David
Country: UK
ok, i understand now!
re the maths bit could you use another similar neck as a guide or are there good websites / charts for the measurements?
PostPosted: Fri Nov 22, 2013 2:26 pm
First name: duh
Last Name: Padma
Ya Chris Pile, him method will work.
But what you really need is
The Offical Neck Stretcher
by
OLF Tools
$20, in an envelop C/o dis here forum and
Lance will send one out to you ASP.
bliss
